When checking the output signal of a Marshall 9200 power amp, I noticed that the positive portion of the signal was changing in amplitude on a regular interval. The input signal is solid.
Changing the balance pot doesn't really help, although it evens out the symmetry. Bad transistor (the PI circuit is unusual on this amp) or aging caps
The behaviour is the same on both channels. Might be part of the design, but I find it odd nonetheless.
Check it out here:
Check it out here:
