I recently bought a red face SWR Basic 350 bass amp head off Craigslist. i bought it cheap because the seller said the amp was making a "buzzy" sound. I took it home and sure enough it was making a horrible distorted guitar sound when I played bass through it.
I isolated the problem to the power amp section. I put the amp on the bench and ran a clean sine wave into the input. The output sine wave of the 'tuner out' is clean with no clipping. The output of the 'effects out' is clean (until you increase the gain knob then the wave clips evenly top and bottom). The output waveform of the 'speaker out' clips very early when the gain or the master is increased slightly. As you see from the attached photo, only the top of the waveform is clipped and it is clipped severely. Where should I start looking for problems? Thanks.
