Hi,
my modded JTM60 has some slight channel bleed from Boost channel to clean. Not too bad but noticable. Very faint and buzzlike.
I found out that if I turn down the gain knob in boost channel, there is no bleed through to clean channel anymore. I did replace the relays after doing other mods, but don't think they are the problem and I suspect a capacitor somewhere.
Also, I replaced the four elkos C102, C106, C109 and C110 (22uF 450V) as a part of recap job after the mods. Used the same values as original but from Panasonic. Also replaced the C7 on VR6 with same value capacitor 100pF but from Silver Mica.
Here is a schematic with the mods:
And the original schematics:
