Hello, Everyone.
I was hoping please for some advice from the many experts on this site.
Problem: I have a Peavey Valveking 112 that screams/howls like a banshee as soon as the standby switch is flipped. All tubes have been tested and new ones tried just to try them. All controls are set to zero, it makes no difference. Resistors have been tested, diodes tested, electrolytics have been replaced, this amp is the older first edition, preventative maintenance. The trouble prone relays have been replaced for good measure.
I took some measurement: No signal, all controls are at zero, clean channel, gong into 16 ohm dummy load. All measurements in DC with ground to chassis, even the heaters.
V1 V2 V3 V4 V5
1 166.4 193.3 191.7 122.2mv and goes up to 320mv 16mv up to 320mv NOTE; Pin 1 not connected/used for V4 or V5 6L6GC on schematic.
2 2.9mv .7mv 2.6mv 12.35 5.46
3 1.079 1.27 1.31 437 436
4 -1.2mv -4.8mv -.6mv 434 434
5 -1.1mv -4.8mv -.7mv -54.6 -54.6
6 180.6 257.7 289.9 n/c n/c
7 66.3mv 87.1mv 27.8 19.23 12.33
8 1.39 1.83 90.4 -2.6mv -2.4mv
9 5.42 5.45 5.45 n/a n/a
I've pulled the preamp tubes one at a time and it only quit screaming when I pulled V3.
Injecting a signal can be traced to V4 & V5 pin 5 but is very distorted. (still using a dummy load and signal tracer). The volume control at the zero position has much static, moving up you can hear the test tone, moving higher it breaks into more static.
Pin 8 of V4 & V5 have ground, tested not powered up, with 47 ohms of resistance. I'm not sure what that's all about, something to do with the texture control.
Here is the kicker. I wasn't worried about my bias with 437vdc and -54.6 of bias, but I tried my bias king tester. The tester showed no current going through pin 8, it didn't even light up the display. I tested the Bias King on another amp and it works perfectly.
I'm ready to solder pin 8 of both tubes directly to ground with a 1 ohm resistor and see what's going on.
If you've made it this far through this nightmare, THANK YOU! What am I missing here? Any suggestions/thoughts would be greatly appreciated.
Thank you!!!
V1 V2 V3 V4 V5
Thank you!!!
