Friends....
I have another thread open on my Peavey Ecoustic 112 - Loud Hiss. I want to ask a general question about Bypass Caps on Op Amps and didn't want to bury the answer in that thread. So here it is...
As I trying to clean up some noise and hiss in the amp, I noticed that identical Op Amps (4558) have some instances where the V+ and V- pins have a .047uf bypass cap and others that have a .1uf cap. Other Op Amps do not bypass caps.
If you look at the attached image, you will see the Guitar Channel's first stage Op Amp has a cap on the V+ and V- pins. If you look at the Mic Channel's first stage Op Amp, the V+ and V- do not have a cap. There was space on the board to add one but the designers did not. On the PC board, these Op Amps are somewhat separated from one another- I don't know if that makes a difference.
Could it be that the decision to use a cap is based on proximity to other components or does it come down to electrical characteristics of the circuit? I am looking for some reading material to understand this.
Thanks in advance.
Tom
Thanks in advance.
Tom
