Anyone seen this before(the pics that is.
Has no output. preamp out works.
3 tubes test good. The one that looks like it was super glued into the socket is shorted plate to cathode.
Good sockets pin 2 25vdc 54ac
pin3 485
pin4 480
pin5 -40
pin7 25vdc 54ac
The bad socket voltages are intermittant but pins 6 and 7 show 25vdc 54ac.
Filament voltages seem way off. I'll pull out the simpson to verify them when i have a chance. Inside it looks like a glue mess any idea what it is? It doesn't look like it is from the caps though.. looks like I will also have to drill out the rivets to get at pc board.
Ot primary blue and brown 80 ohms blue and red 40 ohms brown and red 39 ohms.
Schematic attached.
Thanks,
nosaj
DUEL_212.pdf
pin3 485
pin4 480
pin5 -40
pin7 25vdc 54ac
Schematic attached.
Thanks,
nosaj
DUEL_212.pdf
