Originally posted by nosaj
View Post
peavey duel 212 no output
Originally posted by 52 Bill View PostI first test stuff like that by touching the tip of a hot soldering iron to it. If it's wax, it will melt very quickly. If it's some sort of glue, it may or not melt, but it might give off some sort of odor that will suggest what it is made of.
And jumper the filament wires past the molex(?) plug.
nosajsoldering stuff that's broken, breaking stuff that works, Yeah!
Originally posted by nosaj View PostI soacked the socket in Goo gone. used a small drill bit with my fingers to clean them rinse it in naptha let it dry then held a lighter flame to it for a short bit. looks better and passes continuity not intermittantly. No continuity between any separate pins. Now gotta pop rivet and solder the socket back in.
nosaj
Thanks all
Originally posted by nosaj View PostAll back together now 6.2 on the filaments. Put the 3 jjs back in and one sylvania I had just for testing purposes. Everything sounds good little extra hum I m guessing from mismatched tube. Order a new set and check it out.
Thanks all
nosaj
Thanks,
The DC voltage on the grids tells you almost nothing except that you have bias voltage. Measure the current for an actual bias reading. That said, it probably worked for years like that and will probably work for many more as is."I took a photo of my ohm meter... It didn't help." Enzo 8/20/22
PV amps were never "auto-biasing", what they were was a fixed and non-adjustable bias that was by design cool enough that almost any tube would work in it. That -50v won't give you the magic 70% that everyone just HAS to set it to, but the amp will be strong and clean with good tube life.Education is what you're left with after you have forgotten what you have learned.
Originally posted by Enzo View PostPV amps were never "auto-biasing", what they were was a fixed and non-adjustable bias that was by design cool enough that almost any tube would work in it. That -50v won't give you the magic 70% that everyone just HAS to set it to, but the amp will be strong and clean with good tube life.
Thanks,
Thanks all
nosaj
The bear trap clamp was not holding the tube and needed retensioning. There was no way something could have gottin to the socket the way i found it. I really think someone glued the tube in which in turn went conductive and caused the issue.
Not that the offender will cop to it, but thats what I think.
So if I want to check the amp for quietness before I get a new quartet of tubes. The amp is set on 16ohm(which is what the speakers are( it was on 8ohm when I aquired it)
I believe I can just leave 2 power tubes in (2 outside or 2 inside tubes ) and put a 8ohm speaker to see how quiet it really is.
Am I correct in this belief?
Thanks,
Originally posted by nosaj View PostI believe I can just leave 2 power tubes in (2 outside or 2 inside tubes ) and put a 8ohm speaker to see how quiet it really is.
Am I correct in this belief?It's weird, because it WAS working fine.....
Originally posted by Randall View PostSet the impedance switch to whatever the speaker load is, this is independent of whether you have 2 or 4 tubes running. However, how quiet it idles may be effected by matching of the tubes, so running 2 of the tubes you have now may not tell you how it will perform with a new matched quad set.
Yes you are. It shouldn't matter much for test purposes.
Ideally, if you want to remain impedance matching, with 2 tubes pulled you set the switch to be double whatever the cab impedance is.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Yes^^^^^
IMpedance mismatch might affect tone in a subtle way,and it might affect efficiency of power transfer from amp to speaker. But what it won't do is create noise. An unbalanced power stage can have more hum than we like, but that isn't impedance, that is 2 or 4 tubes instead of 3 or 1. For testing this it really doesn't matter wha tyou set impedance to.Education is what you're left with after you have forgotten what you have learned.
Just a note from a guy that bought a non-functioning Duel 212 about 6 weeks ago.
Got it cheap at the local swap meet, and of course even though all the tubes were present, it didn't work. (What a suprise, it also took me some time to figure out where the 12AX7's were.)
I started looking things over before I tore into it, and noticed the 4 6L6's were not lighting.
Took the amp out of the cab, and noticed the ribbon cable Molex plug end that plugs into the 6L6 board had overheated and had burn marks. I quickly figured out it was the heater voltage pins. I cut the Molex off, removed the pins at the 6L6 board, then soldered the ribbon directly in. Later, after talking to Peavey customer service, they admitted that that was a problem they were aware of, their fix was to change the pins in the Molex connector to a design that had 4 contact faces, not two like mine did.
As for your problem with the "glue" that you've seen on the PCB, if yours was built like mine, it is glue, and mostly on the large radial electrolytics to keep them from moving around too much in rough service. I haven't found a way to remove it (yet) but perhaps I'll try the heat gun.
My next project is to install a 120 vac fan to remove some of the heat that 6L6 area gets, that can't be good in the long run.Last edited by gene; 05-30-2016, 01:56 PM.
Originally posted by gene View PostAs for your problem with the "glue"? that you've seen on the PCB, if yours was built like mine, it is glue, and mostly on the large radial electrolytics to keep them from moving around too much in rough service. I haven't found a way to remove it (yet) but perhaps I'll try the heat gun.
Yes it was best to direct solder those filament leads to the circus board.Last edited by Leo_Gnardo; 05-30-2016, 05:18 AM.This isn't the future I signed up for.
The secret to hot melt is freeze spray. Hose the blob of glue down, with freezit, and it gets real brittle. You can then easily shatter it and brush it away.Education is what you're left with after you have forgotten what you have learned.
