I have a SVT II Pro that came in with a broken 6550 output tube. I also found a burnt circuit trace between pin 11 of J11 and R66. I repaired the circuit trace and powered up the amp with a replacement tube and the other 5 original tubes (all tested good, no shorts and very close on current draw). The amp stays in protect mode( red led) and the bias led's do not light at all. I measured -89 VDC at pin 13 and 15 of the tube board which are the cathodes of the 12au7 biasing tubes. Schematic calls for approximately -45 VDC. No high voltage at the power tubes as the protect circuit has cut off B+, I presume. My first experience with this Ampeg protect circuit. Any suggestions?
ampeg_svt-2_pro service manual.pdf
