Another jcm 2000 project ....
this one is a dsl 401
The clean channel works fine- sounds great , but switching to the OD ch. , i have almost no volume...if the gain and master are on 10 i can barely hear signal on OD2 mode...od 1 is silent.
i have a big voltage drop somewhere on the power rail to the pre tubes ...yet the clean channel acts normal
for example i have 0v at the junction of r77 and r81
all the resistors are good down the rail starting at R32 , but after each one the voltage is dropping very low
all the plate resistors test good , im somehow getting 90dvc at pin 1 - V1 , but no voltage at the plates at v2 / v3
i noticed r55 / r77 / r79 are getting very hot , but r81 is cool to the touch
i just cant find any bad resistors....could it be one of those transistors such as t9 / t12 etc, shorting to ground?
after V1 it says "ODMUTE" after pin 7, what is that?
