It has had numerous problems in its lifetime but this is the newest. Usually after its been running maybe 2-3 sometimes 5 minutes it will start making snapping or popping sounds. I definitely know its in the preamp as I've fed the preamp into a seperate power amp (that doesnt have issues) and it does it. Ive swapped out all of te tubes for a brand new set of tubes and the problem remains. I haven't tried feeding another preamp into the Ampeg's amplifier section to see if it's just a preamp problem or if it affects the whole amp.
Anyone have an idea what the problem might be? I'll try to get into the amp in the next few days to see if it affects the power amp section also.
