So I inherited a Ampeg SVT in very clean shape MTI era. All original caps inside measuring (out of circuit) 50uf out of tolerance in a couple caps (the 100uf 40uf multi section cap), all caps were off a some to a lot, so I ordered a SVT cap kit. It was working prior but mushy and a bit noisy, a rocker eq switch in the normal channel was not working either. Now after a total recap job the plate volts read good 650v (tubes in) and bias reads well per Ampeg bias calibration specs.
But only hum, no signal passes, hum gets louder as volume is increased tells me a preamp check is in order. All heaters light up.
Obvouly I screwed something up. In the pre-amp I only changed the one 40uf cap. I was planning on doing the 12dw7 conversion but I will wait until I sort out my mistake.
Having never worked on these any Pointers?
