I am amateur at this. I have a bassman 135 that i have replaced the screen resistors and sockets and electrolytic caps. Put new tubes in and installed 1 ohm resistors on pin 8.
I have readings on grid pin 5- -57.9v plate pin3-502v cathode pin8- 20mv and i multiply pin 3 and pin 8 and come up with 10w static dissipation.
My question is that except able or should i try to get a higher reading on pin 8. i will be using the amp for guitar. It doesn't sound bad, but i would like to have things correct.
