I'm hoping some of you guys can help me figure this one out.
Amp: Orange AD30HTC (4 x EL84, GZ43, 4 x 12AX7)
Condition: No sound. Not even a peep. No hum, no scratchy noises or pops when I touch the leads of the DMM to the EL84 plates. Nothing.
Background: The amp had a low volume condition. Constant low volume, power level equal to say, a 5W amp. The tone and gain level was otherwise fine. The condition persisted through 2 different sets of trusted tubes and all the voltages were spot on, so I ordered an output transformer (even though it tested ok). The amp sat for a few weeks while the transformer came in, and now there's no sound.
Current condition and testing:
I put a new output transformer in it. There's zero sound with that OT, or with the factory OT. All the voltages look spot on. OT CT, primaries, and EL84 plates are all showing proper voltages in the 330-340VDC range. EL84 cathodes in the 11V range, and all voltages including pre-amp seem to be in spec. B+ rail voltage drop resistors measure fine, EL84 cathode resistors measure fine. Nothing in the amp is disconnected, burned, or has any visibly severed connections (that I can see). 6.3VAC heater voltages are also in spec. All the tube heaters are visibly lit.
The only thing odd that I saw was that the OT primary leads were reversed when I went to pull the factory OT. Though the amp is non-negative feedback. The amp is a 2001 model and has been functioning for years like this.
Schematics and test procedure sheet available here:
The Orange Amp Mods page
