I have a '92 Ultimate Chorus amp in with no output. Quick check reveals sound out when going into FX return jacks (it has a mono and a stereo, both work). I trace signal on the clean channel thru U1 pins 1 and 7 up to the treble pot side of R20, but nothing on the other side of R20, and thus nothing to U4. On the boost channel, I see signal on U2A on pin 1 up to the junction of C16 and R31, but on the Q2 side of R31 nothing.
I suspect something to do with channel select switching, but I am unclear on this. Q1, Q2 and Q3 are involved I believe, but I don't get the role of the double diodes CR4/5, CR3/15 and CR13/14. The channels appear to be switching, as the LEDs are functioning, albeit with a thud. The chorus appears to be functioning, as the LED comes on and modulates between red and green with the rate control.
The 16v rail is good, but the -16v rail is at -13.2 volts. And the amp passes signal for a brief second at powering off.
Any ideas?
http://www.electronicstudio.net/sche..._Schematic.pdf
Any ideas?
