Hi,
I just picked up a Marshall MG15dfx for £10. The overdrive channel sounds great but the clean channel is dead. The effects part of the amp is dead too. I researched online and I read it is a good chance it is the fuse to the channel. There should be 2 on the circuit board I also read. I opened up the amp and saw what I thought looked like the fuses. I tested them with a multimeter for continuity. The first beeped showing the fuse was ok. The second didn't make a noise. So I took it out and tested again, still nothing. I also got the schematic online.
The part is connected to C47 and is labelled 1000/25V on the schematic.
I took a picture of the fuse (if it is a fuse) and the markings on it. F2P1 33RJ H5N.
I've looked online and can't find anything. Is it a fuse? Any help would be very much appreciated.
Thanks
Thanks
