Hi there,
Got a Gallien-Krueger to fix here but I can not find the problem and need some help.
The amp is distorting in the clean and crunchy channel. I already tested the Pre Amp section and it is ok. No issues. Plugged the bass directly in the return to check the power amp section, and the issue is there.
I have emailed GK for the schematics and they sent it to me. I am attaching it to the thread, both schematics. The pre amp board and the power amp board.
One thing I need to mention before I start, is that I don't have a scope and neither signal generator. I am using only the multimeter. So, one of the first things I started to check was the bias. There is a test point for the bias measurement. In the schematics, they say to set the bias to 10mV. So, to my surprise I got nothing. 0 volts. So I took out the heat sink and tried to measure again the bias directly in the board. Same result. Time to check the other test points.
Measured the rails of 60Vdc and got +65Vdc and -65Vdc. The 15Vdc I got +14,8Vdc and -14,9Vdc. In the 35Vdc rail, something weird happened. Looking at the schematics, I should measure +35Vdc in one side of R36 and on the other side +60Vdc. The same goes to R38. In one side I should measure -35Vdc and in the other -60Vdc. But in the points I should measure +-60Vdc, I got a reading of +- 65Vdc. So, my initial thought was that R36 and R38 were shorted. But they aren't. They are ok. Measured both.
Do you guys have any tip about this?
Thank you a lot for the help.
