Good day! I am a first time poster here, and I am looking for some guidance. I have scoured the web and cannot find anything that is similar to the issue I am having. So, allow me to backtrace a bit, and give you guys and Idea of what is going on.
I had some crunchy knobs that needed to be cleaned out, and asked my brother (a mechanic by trade) if he had any Contact cleaner I could borrow. He lent me some and I sprayed it all up inside those pots. Got them nice and smooth... until they started to feel loose, and some very stiff too. Well turns out it was the wrong contact cleaner, and it was not safe for plastics, and I melted the shafts. So I ordered some snap-in pots online, looked up all of the resistances, and got everything desoldered, and resoldered. The first time I plugged in the amp, it came on fine, but the volume pot would not work. I still had sound though, a very clean, chimey, almost Deluxe reverb sound, that got overly loud overly quick on the master volume. So I figured I did a poor job soldering, and tried again. This time I got the Volume to work, but the master would cut in and out depending on if it was nudged the wrong way. And over all even the cleans sounded kinda muddy and bad. So I took the amp apart a third time, and worked on my soldered joints. The Master is good again, but the Volume will no longer work! I get very crisp clean tones, but 0 distortion or volume increase from the volume knob. I took it apart a fourth time, and ended with the same result as previously.
All my tubes glow as expected, there is no weird humming or buzzing. any distortion pedals sound like garbage in front of the amp now. I am thinking I either burned the board some where, I messed up one of the solder joints on the PCB mounted Valve socket, I messed up the R8 plate resistor between V1 and V2. or I plain have a bad Volume pot.
Any ideas or suggestions?
