Hi..
This came in with the usual 'everything works apart from there's no audio from the guitar or the headphones' fault. Usual suspect (codec) cured it.
However, It has a strange fault that was there before I replaced the codec and is still there now.
Best I can describe is that the amp works exactly as it should for everything. Except.. when you turn the master volume pot, with or without a signal, it 'groans'. thats the best way I can describe it.
Imaging a creaking door, if you open it very slowly you get the slow steady clicking but if you open it quickly you get the 'creak' or 'groan'. well that's what the pot is like. Volume of groan stays the same.
At first I thought it may be some digital volume control signal that was leaking through from somewhere but on browsing the forums it seems that the master pot is the only pot that isn't digital and works just like an ordinary analog volume pot.
My main problem is that I cant find the correct schematic for this? I have diagrams for the spider iv 75 but they all seem to be a slightly different variant. The one I need has the master volume pot labelled as R723. Anyone shed any light?
When the pot isn't being turned it works just fine and controls the volume as it should. The noise only happens whilst turning.
