Well, I really did something stupid. Swapped out all my tubes but installed them backwards s in tubes 1-7 were put in 7-1. I know, I know.... Turned on saw a bright flash. Immediately turned it off. Realized what a dummy I was. Replaced the blown 1a fuse. Other checked out fine. Powered it back up and still no luck. Power amp tubes are glowing. Pres are out. Checked voltages and I am getting 130 volts at the fuse and around 370v for b+ and b++.
Any advice on what to check or swap out would be greatly appreciated. Thanks!
http://www.bustedgear.com/images/sch...classic-30.pdf
