Friends...
I picked up a Sprague Tel-Ohmike TO-6A from eBay. I thought it might be a "fun" item to have around. I have seen posts here were we talk about the Tel-Ohmike but none about the unit itself.
Initial testing says the unit is working- "accuracy" might be another thing.
And of course, the first thing I do when I buy something old is to open it up and have a look around.
The tubes test ok. The "Eye" glows brightly. But some of the Electrolytic caps appear to be cracking and bubbling at the leads.
Electrolytics include:
12uf, 450 vdc
5uf, 25 vdc
20uf, 350 vdc
50uf, 3 vdc
I think I can probably go with 10uf, 4.7uf, Should be able to find a 20uf, and a 47uf caps.
C10, which goes to the Power Factor control, calls for a 2uf, 200 vdc, polyester film. There are (2) 1uf caps in parallel for C10 (just like the manual says there could be). There are other polyester film caps in this unit.
So the electrolytics are easy to get to and replace. But I am curious about the polyester caps. Did they use polyester back in the day because they were cheap and available or was there some other "property" or electro-consideration that went into the design choice?
Thanks in advance... Tom
12uf, 450 vdc
5uf, 25 vdc
20uf, 350 vdc
50uf, 3 vdc
