So I am working on fully repairing this amp but ran into a bit of a snag. So the symptom is simply a bit of DC on the output in the first 2-3 seconds that it powers on. You can almost see it on the speaker as it pushing out just slightly. The amount of DC at power up is very small 800mvDC and I measure about 400mvAC where both die down to nearly 0mv after 2-3 seconds. After that the amp sits at 2mv DC and is passing clean signal. Also, to note this is not that pop noise that amps make and it really is a sizzle/hum that lasts for about 2-3 seconds as it first powers on and then the amp works perfectly.
It was basically repaired after I replaced Q11 and some open resistors. The noise is not coming from the pre amp and is definitely coming after preamp out jack. I have checked out the mute circuit but all of the components in that area are good. However, TP24 says it should be -15.5vDC but powering up the amp shows nearly 0vDC at TP24. Measuring on the other side of D38 show -16v. Not sure really if the mute circuit is to blame or what.
I have looked at AC ripple off filter caps but one the amp is up running it is 80-100mvAC ripple. All solder joints have been looked over and should not likely be the culprits.
Any help trouble shooting this would be greatly appreciated thanks.
http://music-electronics-forum.com/a..._schematic.pdf
