This amp came in with a blown fuse. Replaced it, and both power tubes. I tried 2 sets of new tubes, because I was getting different bias readings for each tube. I checked cathode ground, grid bias voltage, screen voltage etc... all check out good. Yet, 65ma on one side, and 40ma on the other. Pulled the tubes and got ~100ohms from each primary to CT. Swapped tubes with each other, same result. Both flyback diodes seem ok. Again, both tubes are getting identical negative bias voltage on their grids.
So the very odd anomaly that is happening as well - I cannot get a voltage reading on the 40ma side. When I touch the plate, the amp hums, and my meter reads OL. My meter is a 600vDC meter. I get a 330v reading on the other plate. I'm confused by this. Anyone had this happen? I can guess that it's the OT, but wondering if anyone has experienced this.
http://support.fender.com/schematics...atic_Rev-D.pdf
