Hey folks ,
Got this Twin back in with another issue. Doesn't seem to be completely switching to the "Dirty" channel. Originally I had recapped , and replaced the input jacks on channel one ( Switching Channel). Channel one works when plugged in for clean ,and channel two works as designed with both channels mixed. Just when you are plugged into channel one ,and try to switch to channel two it doesn't completely switch?
Owner says he can sometimes jiggle the jack ,and it will kick in ? I have it apart ,and checked solder joints ,and such. I was thinking this could be an Optocoupler issue ? I removed LDR1 ,and 2 ,and tested them.
I connected a 9v battery - side to the - ,and used the + side of the battery along with the 1k resistor to turn it on /off. I tested with the - lead of the DVM on one end ,and the + on the other leaving the center open. On one of the Optos(LDR2) was reading 8.8k ,and the other (LDR1)around 5.6k. Tested again with the meter set a little lower. With the + lead of the DVM connected to the center (common?) I am getting 4.8K ohms on LDR2 opto ,and LDR1 is getting 2.4K. I think according to what I'm seeing on another site at 10mA current when it's on I should get 5k ,so could be the one is bad at 2.4k ?
I may swap positions on these to see if the problem moves.
Any other ideas appreciated.
