Greetings,
I picked up a Silvertone 1474 Twin Twelve combo amp in the sort of shape that tells me someone got frustrated - cut cord, broken fuse holder, missing reverb tank, no knobs. On the upside, the Jensens are intact and in great shape, the transformers seem fine, and it doesn't look like any repairs were attempted in its past. Several tubes appear original, all electronics intact including the red Planet Lyticaps and blue Sangamo caps, none showing blistering or other damage. Sockets are in good shape, resistors measure within reason. All in all a good candidate for a first project.
I did replace a badly blistered and physically leaking Pyramid PIO cap with a Sprague. Replaced the fuse holder and 3W fuse. Replaced the cut cord with a 3-prong and grounded the green to a post I added to the metal casing. Found and repaired a broken solder joint from a cap to a post. And shorted the connection where the reverb tank would be wired in. So far, so good.
I replaced the speaker wires, and this triggered my first question - how should they be wired? The old ones were not all connected so I have clips holding things in place for the moment. The output transformers each have a black and yellow wire leading to a 3-contact row of terminals where the blacks are connected to the middle, grounded node, and each yellows to the outer posts. From here I have wires running from the ground to one side of each speaker, and the yellows to the other post on each speaker. The two connections on each speaker are also "bridged" with a choke mounted next to the speaker inside the cabinet. The chokes don't appear in great shape, and I don't have any reason to presume them good or bad. If any of this is unclear I could draw a diagram.
So what's confusing me is that my multimeter shows continuity between both either speaker post on either speaker, and any of the 4 posts and ground. Everything is electronically connected to everything else. Of course, we're talking about metal posts on a metal speaker, so it does seem obvious that "yes, there is continuity," but still, something screams "this is wrong." How's this work? Do I rebuild the 3-contact row of terminals and ensure each is isolated from the others? Did the chokes come correctly wired? Why are these speakers different from every other pair I remember looking at?
Tonight I wanted to start reforming the remaining caps, so I put in the preamp tubes, left out the rectifier tube and output tubes, and powered up on a Variac at about 25V. I also have an inline circuit limiter (the Weber-style 100W bulb in series). No issues so far so I brought it down after a bit and added the rectifier tube back in. Will let it run an hour or so and then repeat at 50V. Until I figure out whether the speakers are wired correctly for load I won't crank it any higher.
So am I on the right track? All suggestions, comments, corrections and guidance more than welcome.
Cheers,
-Eli.
Cheers,
-Eli.
