I'm having distortion issues with my ultralinear pro reverb.
Schematic here: http://www.thetubestore.com/lib/thet...-Schematic.pdf
Distortion is most noticeable on the lower notes, quite pronounced in fact. Only happens on the Reverb channel. Normal channel is completely unaffected.
Things I've tried (Aside from guitar/ cable/ speaker swaps)
Tube substitution - no change
Reverb disconnection - No change
Vibrato select/ deselect - no change.
Reverb controls also have no affect.
Preamp Votages are:
1 2 3 4 5 6 7 8 9
V1 253 0 1.87 0 - 0 249 0.02 2.11 0
V2 245 0 1.98 0 - 0 242 0 2.12 0
V3 399 0.07 5.7 0 - 0 399 0.07 5.7 0
V4 263 0 2.1 0 - 0 227 0.03 2.1 0
V5 220 62 96.7 0 - 0 212 67 97 0
V6 -0.02 63.5 97.6 0 - 0 212 68 97.6 0
I've popped a signal gen' into the guitar input for the reverb channel & scope on V2 pin 7 and the sine wave looks fine.
If I pop the scope on pin 2 of V3 I get this:
Putting the scope probe back on the other side of the 500pF cap connected to V3 pin 2 and the signal looks fine again.
Turning the bass to zero cleans that wave up. Turning the treble all the way up improves it slightly. Mid control has no effect.
I'm a bit lost as to where to go next. Not quite sure if that scope photo is showing actual distortion or out of phase harmonic?
Any advice appreciated.
Preamp Votages are:
1 2 3 4 5 6 7 8 9
