Hello guys.
I have an Ibanez TBX15R amplifier.
I had the guitar's output cable attached to my aplifier. Then, an object fell on the
edge of the cable (where it was inserting to the amplifier) and broke the
amplifier's input jack.
I opened up the amplifier and the input jack was OK electrically. It works fine. But
what broke was the plastic thread that exits the amplifier.
Therefore, i cannot connect a guitar cable to my amplifier, as the input jack is not
in place, aligned with the hole in the amplifier, but it is somewhere inside.
I applied super glue as a temporary solution and it worked for a while but it broke
again as expected.
Finally, i decided to replace the input jack. I opened the amplifier again, and i
saw that this particular input jack has 6 pins. I went to electronics stores and
told me that there are 4 pins, the other 2 pins are for the metal base. Though i
doubt that, because all the pins are in electrically conductive areas in the PCB.
This is the picture of the back of the PCB of the input jack.
Does anyone know what input jack this particular amplifier uses, and where i can buy
one?
This is a picture of the input jack of my aplifier.
The only documents i found online about my aplifier state, '1/4" phone jack input'
(Source (page 12), http://www.ibanez.com/world/manual/amp/TBX.pdf)
Thanks a lot!
again as expected.
one?
Thanks a lot!
