Presonus 16.0.2 power supply -- d16 burned
    Please post the diode value.
      1N6267... can you also take a look at the value of U8 for me in return? Mine is busted needed to replace too. Thanks in advance Click image for larger version
        I was trying to confirm 6.8 or 68 number on D16 diode. I see 1.5kE6.8 Click image for larger version
Name:	D16 presonus.jpg
          1.5KE series is a transient clamping type diode. I agree it appears to be the 6.8A (breakdown volts) version.
          Also, there is no 68 version so it must be 6.8
            Thank you for post the number, that clarified my doubt.
            U8 number is: 2807-2
            http://www.ti.com/lit/ds/slus163b/slus163b.pdf
            R31 number is: 2001
              R31 number is: 2001
              1.5KE and 1N6267 are just the same TVS diode. I just fixed mine, thank you are right U8 is 2807-2, presonus customer support told me then.
                hi everyone,
                mine too is is burned out as well, sorry for my english.
                i need the value for:
                R16
                R8
                any help will be gladly appreciated.
                  R16, R8
                  Originally posted by mashrum101 View Post
                  hi everyone,
                  R16
                  R8
                  I checked my board...,
                  R16 = 1 k
                  R8= 2,7 E
                  hope that helps,
                  greetings from Salzburg
                    If the supply does not run without a load, it could be part of the design - I've seen that in one particular supply type.
                      The D2 is the MBR2045CT.
                      The D16 is the 1.5KE6.8A.
                        hello
                        send value
                        R13
                        D13
                        Q1
