Hi all. I've got a Vox V1032 that I'm trying to restore. It had a number of modifications so I decided to update to one of R.G. Keen's replacement boards with all new components (except for the MRB). The amp is running, but there are a couple of likely related problems. The sound coming out of the speaker has a fair bit of distortion at all volumes. Oddly, with the volume all the way off there is sound, getting quieter till about 2, then getting louder until it makes crazy distortion/oscillation with the volume above 8 or so. To preface things, I am distinctly amateur with electronics. I know how to read schematics and layouts, but I don't understand the whys and hows of a circuit which makes troubleshooting very difficult. I've checked and re-checked my wiring, found a few mistakes I've fixed, but I'm stumped.
The main transformer seems to be working alright, though a bit low - thought the power supply the 33.5V source reads 31.5V, the 27V source reads 26.6V and the 17V source reads 16.6V.
The transistor voltages are within the range I'd expect on Q1, Q2, Q3, Q4, Q7, Q8, Q9 and Q10. I checked the transistors at the Collector, Base and Emitter where I could. Q5 reads 0.7C, 0.6B and 0.06E which is substantially low on the collector (should be in the 2.5-4V range). Q6 is wrong across the board at 12C, 5B and 4.5E where it should be 15-16C, 1.4-2.4B and 1-2E. Q11 reads 26.4C, 10B and 9.5E where it should read 27C, 4.5B and 3.8-3.9E. Also, the voltage on the emitter changes when I move the speed control, from 8.3V with the speed at 0 to 9.5 with the speed at 10.
The reverb pan has 72ohms at the input and 184 at the output. This is out of spec - according to the VoxShowroom website, it should be 1475 ohms at the input, and 2250 ohms at the output. I tried using the pan from my Buckingham, and while there was much much more reverb, the transistor voltages remain the same and there's no effect on the distortion or odd volume behavior.
The amp also has an "E-tuner" feature, which appears to be working and doesn't have any obvious distortion. The volume, treble and bass controls have no effect on this signal but the reverb and tremolo do. Turning up the reverb adds some of the distortion noise on the instrument inputs. Tremolo works as expected and doesn't otherwise affect the signal.
I got an oscilloscope and traced a generated signal through the preamp, images and description below. As I said, I don't know much about why electronics do what they do, just that they do. That's part of why I wanted to work on a solid state amp - less voltage! I'd love it if anyone has suggestions on further troubleshooting.
Thanks so much, Mel
Now, on to the scope views. First up is the signal itself. It's a sine wave with start frequency of 10kHz, amplitude 300 mV and offset of 0V. I'm not sure why the signal has spikes or isn't completely smooth; I assume I missed a setting somewhere.
![](http://s20.postimg.org/klk8m5avt/Pico_Gen_Signal.jpg)
Next I measured the signal at the input 1 jack. It looks pretty much the same, though the spikes are larger.
![](http://s20.postimg.org/uucpryyxl/input_1_w_signal.jpg)
I was curious about the spikes, and measured across the jack with no signal and got this. I did note that the act of measuring itself added noise to the amp output, so perhaps this is something coming from my laptop? The level of noise coming out of the amp dropped significantly when I removed the testing lead ground from the chassis.
![](http://s20.postimg.org/os0hnql3t/input_1_no_signal.jpg)
I reconnected the signal generator and had a look at the signal after R1. The wave seems to have dropped in amplitude and the noise spikes got larger.
![](http://s20.postimg.org/5j80bgqc9/Signal_post_R1.jpg)
Next I put the probe on the collector of Q2. The scale is in volts rather than milliVolts, but it still looks like a sine wave.
![](http://s20.postimg.org/6ms4nfazd/Signal_TP2.jpg)
At the hot lead on the Treble pot, the sine wave is back on the milliVolt scale, but an order of magnitude higher than at R1.
![](http://s20.postimg.org/5yja4hc9l/Signal_Treble_Hot.jpg)
Here's the signal on the hot lead of the Volume pot. Same basic waveform as on the hot Treble lead, but the noise spikes are bigger.
Thanks so much, Mel
![](http://s20.postimg.org/xs9olo6l5/Signal_at_Vol_L.jpg)
