Hello everyone!
I've read several threads on this and other forums about the CS400/800. Enzo's posts were a big help to this point, but i'm stuck now.
A received an old CS400 last week. It's the 2 power board and 2 driver board type with triacs on the output.
It was blowing fuses. I took it apart and on the B channel there were 2 transistors blown.
On each power board the 3 0.1u 250V capacitors were blown with the near by 5W 5.6ohm resistor.
There were a few little resistors that blackened too.
I replaced everything and put it back together.
I took out U1 from the input board.
I disconnected the B channel to get one channel working, so i'm talking about channel A from now on.
As i power it up, my current limiting bulb shines bright.
No DC and no shorts on the output terminals.
I connected an old speaker and a signal from a phone.
On power up there is no output, but when i disconnect the speaker and connect it back, i can hear the music from the speaker, but its like 1V peak to peak and i can hear a loud humm.
I measure around 5V on CR6 on the driver board. I replaced it, but the problem is the same.
My measurements on the driver board ic-s:
I would appreciate any help, because this thing drives me crazy...
Excuse my English, i'm not a native English speaker.
