Maybe somebody here has had some experience with this......Microphone capsules that are set in a plastic housing and somehow glued in place....The Apex line of mics are one in particular....I have no idea of what type of adhesive is used in mics like these....maybe somebody here on the forum might have some ideas....and of course, dealing with plastic one will have to be careful.....
Adhesives
I ran across a method a couple weeks ago on YouTube, how to remove the transformer from an SM57. Involves heating the body of the mic in boiling or very hot water to loosen the gloppy adhesive holding it in place. Might use that idea on your mic. At least it's water & not solvents. The real action starts about 4 minutes in.
https://www.youtube.com/watch?v=rDVzXAgOFYwThis isn't the future I signed up for.
Originally posted by Leo_Gnardo View PostI ran across a method a couple weeks ago on YouTube, how to remove the transformer from an SM57. Involves heating the body of the mic in boiling or very hot water to loosen the gloppy adhesive holding it in place. Might use that idea on your mic. At least it's water & not solvents. The real action starts about 4 minutes in.
Originally posted by TimmyP1955 View PostI'd think they would use silicone, as it would have at least a teeny tiny bit of shock absorption.
Sometimes Iīve seen a type of conventional neoprene based contact cement ... problem is that it uses a quite aggresive solvent: Toluene or Xylene with a bit of Acetone which attacks most plastics.
Although counterintuitive, itīs a desireable property because it helps fresh adhesive to "dig in" for stronger adhesion, but a buitch to remove, because the excess solvent needed to soften it will deffinitely destroy plastic.
Mic capsules in general are supposed to be replaceable, although in many cases it may mean damaging or destroying the old one.Juan Manuel Fahey
Maybe Yorkville can tell you what they use for removal/re-assembly.
I'm thinking something similar to what they use on rubber speaker surrounds.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Originally posted by g1 View PostMaybe Yorkville can tell you what they use for removal/re-assembly.
Cheers
