I have a Yamaha G50 112II amp with a broken reverb unit. This unit is made by Accutronics in Geneva, Ill. (it even says MADE IN USA), and has 2 springs inside.
After I checked everything obvious, I took the reverb tank out of the amp and opened it. On the output transducer, one spring had come out of the small hole where the hook engages but I managed to put it back in place. However, on the input transducer there are no holes to hook up the springs. Instead, the ends are kind of soldered in place. Also, this end of each spring has a thicker part just before the thinner end pin.
I took a couple of pics so you can see what I'm talking about.
It is not clearly visible but on the opposite of where each spring enters the transducer, there is a receiving pipe sticking out with solder inside. That is where I would melt the tin, put the spring back inside the hole and hold it in place until it cooled down enough to hold the tension of the spring.
My question is if these springs can simply be soldered back in place the way they came out or would I have to compensate for any missing piece that might have broken off the end of the spring?
Or would it be a good idea to replace the pin with a small hook and try to solder a piece of wire into the receiving end? This wire would then be fixed to the spring and allow it to vibrate. It probably would have to be able to generate a magnetic field that then can be picked up by the transducer.
