This particular Oliver does not have an exact schematic but this one for the PA100XR is very close with respect to the reverb.
They both use the 6DR7 tube, which I've never seen used in a guitar amp. I ended up buying one NOS so the tube doesn't seem to be the problem.
When it first came in there was some damage on a small board with PS dropping resistors that had collapsed and a 20w 5K resistor opened up. Replaced that so now there is voltage feeding the 6DR7.
All the components in the reverb circuit so far seem to measure to spec.
The original tank is a Gibbs 031-0005-00. It has an open transducer, so I bought a 4FB3A1A from flip tops thinking this amp will be something similar to an early ampeg.
Still no reverb.
Thanks in advance for ideas where to go from here.
I will post voltages on the 6DR7 and 6EU7 soon.
Still no reverb.
