Originally posted by AL78
View Post
Help Marshall vs65r
I think ee established his meter won't work here
AL78- I didn't expect you to interpret the meter drawing quite so literally. No cutting of probe leads is required So long as (1) the capacitor ends up in series with the meter - use clips, wire or whatever and (2) you cannot touch the side that will be probing the amp ( high voltage risk ) it will be fine.Experience is something you get, just after you really needed it.
I do as was described above and I use the free cap lead as a small probe. But for the less experience, I would ground my black probe to chassis then clip a wire to the red probe tip and to the cap, then use another clip wire from the other end of the cap. Now I use that second clip wire as my probe. That way I do not have to hold the cap in my fingers while touching potentially dangerous voltages.
My Fluke meters do not need this trick, but I still wind up doing it now and then when some situation arises. A cap is also a good way to block DC if you want to inject a signal from your generator into the signalpath at some point with DC voltage on it.Education is what you're left with after you have forgotten what you have learned.
While you wait, there are a couple more areas you check do that I just thought of.
You can do the signal generator / ACV measurement on either side of C43, and either end of VR4. Also take the PCB out and have a really good look at the V1 and clean tone control stack areas for bad joints.Experience is something you get, just after you really needed it.
c43 I'm giving 362mv I'get 20mv more or less both sides.
c41 16mv and 9mv c40
I have a question it's R19 the output of the tube?I don't know if we checked either ac or dc
I've checked with continuity test and a magnified glasses the board everything looks goodLast edited by AL78; 03-06-2017, 09:05 AM.
That doesn't make sense. You apparently have a big signal on C43 but not on C40 and/or C41? That's not possible. Recheck where you are probing
IF we take the C43 measurement of 362mV and IC5 pin 2 at 7mV as correct from earlier, then there is an open circuit between C43 and IC5 pin 2. I would expect around 80mV on IC5 pin 2. Measure the DC resistance from IC5 pin 2 to ground and to the C43/R45 junction.Experience is something you get, just after you really needed it.
So since there was some confusion I've redone the test for c43 I connect the pc with a 1000hz 362mv and I get more or less 20mv(as said before)either side
and I get 16mv for c41 and 9mv for c40.To do the second test (c40 c 41) I had to flip the board because those caps have no room to probe.If you think that the c40 c 41 test is not good Please tell a point where I can check again.I have continuity between Ic5 pin 2 and c43 and r 45.Thanks
