I've got very old Marshall Mercury amp with several problems. The most painful is hum. This is 5W amp with power amp based on single EL84 and solid state preamp. The PC board does not look nice - it was seriously overheated. Also the power transformer was replaced and the heater voltage is 5.8V only. When the amp was designed they didn't care much about ground loops. The ground track is a track around the PC board and it creates several ground loops. I already corrected this slightly and the hum is much lower but I still can hear it. Do you think that the hum can be caused by overheated PC board (at EL84 socket)? Or, the hum is a feature of this amp?
I checked (measured) the power supply capacitors and they seem to be OK.
