Music man Bias
  • #31
    oops----didnt have my magnifiers down there...
    heres what i have
    Pin
    1 23v
    2. ac
    3. 739v
    4. 370v
    5. 23v
    6. ac
    7. 65v
    8. 23v
    • #32
      Any chance you got off count on the pins? Pin6 should be empty, pin7 should be AC (heater), pin8 should be 65V (cathode).
      • #33
        Also thinking pins do not match.
        In any case, some voltages (regardless of stated pin number) are meaningful-
        Pin
        1 23v
        2. ac
        3. 739v
        4. 370v
        5. 23v
        6. ac
        7. 65v
        8. 23v
        * ac - ac are clearly ends of filaments. Should be on pins 2 and 7
        * +23V : fixed positive grid bias
        * 739V: plate
        * 370V : screen
        * 65V : cathode
        which means that *actual* power tube bias is 23-65=-42V (minus because grid is less positive than cathode which is same as more negative)
        also plate to cathode voltage is 739-65=674V ... ouch !!!!
        in any case, screens are at reasonable 350V so that helps.
        • #34
          If those voltages are all correct, I'll stick with what I said in post #24.
          • #35
            so would the JE1692 transistors maybe cause that bias imbalance ? its about 14mv difference from tube to tube (ive swapped tubes)
            • #36
              Maybe. But those resistors need to be close also. And are you using a pair of matched tubes?
              So if you stick with a pair of tubes and switch them around, the low reading stays with the socket?
              • #37
                i stuck in 2 new transistors--bias is great now.
                Im going to stick with the Sovtek 5881's for now ...unless the amp eats them quickly !
                • #38
                  By comparison, tubes are cheap. It's not that I'd worry about. I'd be worried about a catastrophic tube failure that takes out the OT. At least make sure you're not over-fused!
