Got a Kustom '36 Coupe here. Came in with bad hum, even in standby...although less so. Found that the power tubes were no longer matched. Got 42ma and 28ma. I had pulled the PI to make sure the hum was in the power amp and it was. I retubed it, bias looks good and matched, but hum was the same. I began testing a bunch of things, then thought well lets double check the PI voltages... so I reinstalled the tube. HUM GONE. Very odd. I'm sure it's something to do with the NFB loop. Could someone please explain, if you know why this is so? Amp sounds great so it seems to be working fine.
http://music-electronics-forum.com/a...m-72-coupe.pdf
