Leaking electrolyte fluid or something else?
  • Leaking electrolyte fluid or something else?
    Hello folks:
    Is the gunk on the V3 cathode bypass cap in the attached pic electrolyte fluid or something else? You can also see some on the V1 cathode cap. This is from a 1976 Fender Vibrolux Reverb. Thanks.
    To me, it looks like a blob of the wax that was used on Fender eyelet parts boards in that time frame.
    Keep learning. Never give up.
      +1 wax.
      http://amps.monkeymatic.com
        Thank you. I thought something like that might be the case. The amp sounds pretty good and was untouched other than someone adding a line-out for some reason. I've removed the line-out and changed the filter caps and bias supply cap, but I thought I'd hold off on the cathode caps for now if I could.
