I have a Northland Baffin II tube amp(same as Teisco Checkmate 18 without the reverb). When I play my strat through the amp and turn the up on 8-10, it sounds great. Breaks up real nice. When I use my tele with hotter humbuckers, and crank up the amp again to 8-10, it sounds great unless I hit low notes on the low E string. When I do this, the note gets this weird out of phase type sound for a quick moment(less than a sec) and then the sound returns to normal as I let it ring out (almost sounds like a laser in a sci-fi movie). Could this be a power tube biasing issue? The plate voltage is 330V. 11.75v across the 130ohm cathode resistor gives 90mA or approx. 45mA from each tube. Or should I be looking to the preamp tube biasing? Attached is the schematic (mine is the same with no reverb). Thanks.
Hitting low strings hard when amp cranked...
It could be the cathodyne PI. They can do some odd things when overdriven sometimes.
The Valve Wizard
Yeah, It's definitely the bass frequencies. The notes get all squishy and drizzly if you know what I mean (i'll try to post a link to a sound sample later today). I'll play with that 30uF bypass cap. Any other recommendations to tighten up the low end? The amp is late 60's/early 70's and is in absolute mint condition but it does have the original caps. I already replaced the tremolo caps to get it working. Which caps would you replace first to clean up these low notes? Thanks.
Originally posted by Zozobra View PostIt could be the cathodyne PI. They can do some odd things when overdriven sometimes.
The Valve WizardIf it still won't get loud enough, it's probably broken. - Steve Conner
Have you tried it with a different speaker (of the correct impedance)?
Any/all ecaps may be life expired if it's been used a lot, or deformed if not.
It would be a good idea to identify failed parts and get the amp working as intended, before attempting mods.My band:- http://www.youtube.com/user/RedwingBand
