Hi,
I am repairing a Sunn Concert Bass that had a catastrophic power amp failure. All 24Ohm resistors were burnt and the power transistors shorted. After replacing these resistors and the 2n3055 transistors the amplifier powers up and puts out its rated output into a load or speaker. The problem is that there is a noticeable crossover notch in the sinewave (clean otherwise) even when signal is fed directly to the power amp input, and it is audible as a slight distrotion when the amp is played. I have changed Q1, Q101 and Q102, and tried different settings of the "bias" preset pot but it has no effect on the problem.
R113, 115 , 121 and 119 were replaced with 22Ohm as I couldn't get 24Ohm ones, but I doubt this is the reason of the problem. All diodes check ok.
Can anyone suggest a possible reason for this crossover distortion?
