I have an original Bassman head AB 165 on the bench. It used to shock people so the owner had the death cap removed and a 3 prong plug put on. Doing some maintenance - Seems to work ok, but I suspect that the power transformer might have some leaky AC still happening. I'm not sure if it's more than normal. It can still tweak you if not plugged into a grounded outlet.
So here are the symptoms. if I use a three to two ground lift adapter plug and defeat the ground to the house wiring I can read 60 volts AC from Chassis to the house ground. If I reverse the ac plug I get 4 volts AC to the house ground. I've tried measuring the amp draw from chassis to house ground in both plug configurations and I don't see any amperage using my Fluke 115. So no real dangerous amperage.
So my question: Is this normal? or do I have a transformer that is leaky on the primary side and should be replaced or is it on it's last legs?
If I measure resistance from either the hot or neutral of the power cord to chassis I get very high resistance (many megs)
