I got the third Fender FM212 in as many months. All three had the same issue, a cement resistor had broken a connection at a leg. They weren't all the same resistor, nor the same leg. On this third one I went directly to moving resistors while it was on, and was able to get signal to pass and verify the problem, so fixing it was very fast. (since I learned the PT must be removed to pull the board). I wonder what is the reason for these common failures in this particular amp?
Fender Frontman 212 - 3 different amps same issue
