I am in the UK.
Here is a strange thing I really don't understand. When certain pieces of old equipment (in this case a Beam-Echo 50s jukebox amp, and an early 60s Selmer Vanguard combo) are connected to the mains they oscillate at something like 150Hz. When I lift the earth (ground) the oscillation stops. On the juke amp the oscillation also stops when a strong signal is fed through, turn the sig gen input down towards mag cartridge levels and it starts up again.
My bench is in my house. The place was rewired to high standards less than a year ago, as we may let the place at some point and we wanted the latest certification. I use an isolation transformer, and I can connect or disconnect chassis earth on a piece of equipment on the bench. The oscillation happens on the bench with earth connected and on sockets throughout the house.
I first noticed it was something to do with earthing because if you pull the plug out of the mains the oscillation stops instantly, it doesn't wait till the equipment starts to cool and the caps discharge, it stops instantly.
I think it is oscillation because on the Selmer the tone controls affect its pitch. Pulling out the first stage valve stops the noise.
My scope is earthed and when I clip the earth lead to the chassis the oscillation stops or is much reduced.
Any ideas at all? It's a difficulty because I can't satisfactorily test either piece of equipment. Meanwhile other jobs go through fine.
