Yamaha EMX512SC
    I see no mention of the health of the + & -15Vdc supplies.
    You do know that these EMX amps have a ground scheme from hell don't you?
    All of those shiny pieces of spring foil inside of the cover have a purpose.
      Here is a pdf file of a MEF member that documented the grounding scheme.
        My bad. The 15v supplies are both good as well.
        Yes all those foil pieces...what a PITA. So are you saying that could be why? Because the thing isnt screwed together?
          I don't Know why.
          What I do know is what myself & the gentleman that posted that pdf file went through on one of these amps.
          The amp will not function properly unless All of the ground points are connected.
          I had one of these beasts 99% back together & there was a ground connection missing at the output panel.
          It didn't like that.
            http://music-electronics-forum.com/a...o-emx512sc.pdf
            That is... crazy. Ok lemme see if I can follow it and bring it to life.
              Jazz, and the guy who documented the grounding: I want to marry you both.
              So indeed this worked. The thing powered up and stayed up. However, I still had no speaker output. As if this wasn't a difficult enough repair already. So got out the scope and found no signal out of the IC101 opamp. Checked and found no +15v supply. The dang ribbon cable wasn't making good contact on the SMPS board. I ended up having to put a bead of solder on the wire so it was a tighter fit in the clip. Phew. Things working completely now.
              Ok, so now for step 67. Lets see if I can get the dang thing back together right, and without disconnecting something in the process. Anyone have a direct line to NASA for support?
                (281) 483-0123
                NASA Johnson Space Center
                  Got the thing back together and functional. Thanks for the help!
                    Glad that you got it.
                    And thanks for the conclusion.
                      You got it. Couldnt have done it without your help. On to the next victim.
