peavey vypyr 30 iverheated
  • peavey vypyr 30 iverheated
    i hqve a peavey vypyr 30 that overheat (i think cpu overheats) after humid entered and overheats in few minutes every time turn it on
    no rpair shops
    is there away to fix it?
    cleaners? heating with dry heat?
    More investigation is needed. What happens when it overheats? Fuse blows? Relay snaps? Other?
    How do you know something is getting hot? Smoke? Scorch marks? Touching?
    http://amps.monkeymatic.com
      i have checked the cpu pcb overheats no smoke the square overheat cpu i think after hot shower humid must have entered now overheats can turn on though nauseating i havr leave it for month hoping that wouldnt overheats all works freat except overheating problem
        Some cpu's run very hot. Are you sure it is the only source of the heat, or is there anything else in there that is overheating.
        What do you mean by nauseating? You said there is no smoke.
          its overheats csnt turn it on very long plastic smell
            Is the processor socketed? Does it have a heatsink?
            If you feel that high humidity has caused the problem, then perhaps a good cleaning of all of the metal contacts will help fix it.
              no rpair shops
              Can you please post a photograph with the part that is overheating clearly marked? Thanks.
                It's more than likely the DSP board.
                (I tried uploading a picture but the site is fighting me. Still)
                This gent has a page dedicated to the Vypyr.
                Lots of gut shots.
                Some VIP 1 Under-the covers Pictures « Vypyr Software, Settings, And Tech Info « Glen?s Projects « The Colbert Homestead
                  I just want to be sure what part we are talking about. It clear that language is going to be an issue especially as my Greenlandic is a tad rusty
                  Hej hvordan går det 'Vyper30'?
                    analog dsp board overheats
                      There is no such thing as an 'analog DSP board'
                      Is it this board? :
                      Peavey_Vypyr_DSP_Schematics.pdf
                      If that is it then check the voltage on the power supplies "VD" and +30, +15, +5, + 3.3V and 1.2V.
                      Most probably, since the board has been overheated, is it damaged beyond repair and replacement might be the best option. But before you do, you should check these supplies.
