It's going to be Ampeg today... sorry.
I do have to take care of this common thing that seems to happen with this little amps.
The Amp have the Power Amp section shut. I did the research and seems like none of the threads involving this amp is solved so maybe it's interesting to have one solved because as far as I can see is a common problem with this amp. The Yellow Fault LED issue.
I know this LED can be turned on by trillions of things due to the switching power supply.
This amp has the preamp working allright until the Send effects jack and the DI out. The Send and DI XLR out are working, so the amp can be used as a preamp ;D. Input, Gainstage, tonestack, limiter, Audio In, and Phones all work ok. Cooling fan is not working and there's no power amp output. Customer told me maybe the amp got hot playing with an active bass and super loud
Didn't check anything, so Any ideas for tomorrow to check?
So many thanks to all
