Got a strange issue: Had a Bassman 10 from 81 with a loud hum. Removed the Hum Balance pot,redid the heater wires to the two preamp tubes and tied two 100Ohm resistors to ground from each leg of the pilot light(6.3v). No issues..yet. Played through the amp loudly. Amp was pretty loud. About 10 minutes in amp blew the mains fuse. One of the 100 hm resistors smoked. Checked all the tube sockets for any bad solder joints or shorts. All new tubes installed. Disconnected the trans wires to test 6.3v out of circuit. Measured 6.8vac figured that was god with no load. Then i measured one side to ground and got 70VAC???
Am i missing something?(Highly possble).
