the volume on my jcm800 has been jumping up and down so i took it into a repair place and he told me it might be a bad master volume pot. because he didnt have the pot on hand he had to special order it, saying it would take almost 2 weeks. i didnt want to wait that long so i figured, having some soldering experience, id replace it myself. i found the master volume pot to be a 1m ohm audio taper, so that is what i picked up at my local electronics warehouse. everything went well in replacing it, but when i turned my amp on and slowly turned the volume up i started to hear a massive amount of some type of interference or buzzing. i played my guitar on it and it kind of worked, i got sound out of the notes but it wasnt as loud as it should be, the buzzing sound was louder then the notes.
my question is, is there some sort of special 1m ohm audio taper potentiometer that i should be using, or are they all the same? or if not the wrong pot, then what could have happened to my amp?
thanks so much for your time!
