This amp had tons of problems. Sitting in a cold storage locker for the last 10 years didn't help. So far i have changed all the jacks and pots out and a dozen or so caps. I have all the power supply voltages sort of back to normal but they seem higher than spec. So searching around I found a FP 470 ohm resistor feeding one of the 6L6 tubes that is burnt through with a bad reading so i think that may be the issue. It is the 415 volt Y feed to pin 4 on the 6L6's and the resistor sits in between. Given my limited knowledge on this stuff,,,
Question 1,,Is there a name for this feed? eg bias, grid, collector??
Question 2,,I know the FP stands for fire proof but i don't have any of these in my collection. Can i use a standard 1 watt 470 ohm temporarily for testing purposes??
Question 3,,. The tube PCB requires removal to get at the parts. When i put it back together Is there any issue mounting the resistors on the visible side/trace side of the PCB?? Simply easier to change out later without removing the PCB.
So there is my 3 questions.
Thanks
Thanks
