Moving right along. The next amp im digging into is this DC3. I remember it being a fairly interesting amp tone wise. Its the only el84 powered tube amp i have had. It has a issue with two of the tubes red plating. I changed out to a new set as per the advice from Mesa and the same thing happens after about 3 minutes run time. I have already cleaned up everything like jacks and pots on the amp, just need to sort out the tube issue.
What causes the red plating and where is the best place to start looking for the problem.
Not sure if i have the schem for this or not. Have to look.
