I'm not sure it's thhe cause of your hum or not, but I question the grounding on your 6L6 cathodes. Do you have an iron big enough to melt those groundnconnections? Usually takes a minimum 50W iron for that. I can see in the pic how the solder is kind of balled up on the chassis. It should be flowed smooth - like your pot grounds.
I"m back at my pretty-much-stock AB165 if you need any measurements.
But given that the hum stops when you pull V2, I think it's somewhere in that stage, or in the mixing right in front of it.
Justin
Justin
